A laser printer series by HP for home and office use. These printers often have problems with the formatter board.
8 Questions View all
Why printer goes direct to ready mode on startup and not printing
my printer is indicating ready always on start up without indicating on other functions and is dormant. what is the problem and how do i solve it?
Update (01/15/2016)
why is the printer showing the ready button only on statup
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
Try a cold reset of your printer
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
A cold reset changes most system parameters in NVRAM to the factory defaults. A cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.'
Score 3
1 Comment:
dear :sir
thank you for your co-operation
i do the cold rest steps but the printer still as before. but still the ready led still on
edrees
by
Add a comment
Add your answer
john mburu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 799
