The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 Questions View all
Can I reuse undamaged back cover?
So essentially I got a Z3 for pretty cheap (200 Euro) however the camera lens is full of dirt which makes the photos come out kind of bad. I was wondering if I could remove the back cover, clean the lens and use new back cover adhesive but keep the same glass cover?
Score 2
Add a comment
Chosen Solution
Absolutely! Just be careful not to damage when removing. It is adhered to the back of the phone and cracks easily. I would use plenty of heat and have plenty of patience when removing the back. I would also check ifixit for a guide, or youtube!
Score 2
1 Comment:
Thanks I'm going to go order the adhesive tonight.
by
Add a comment
I would recommend replacing the entire back glass after removing it.
They are dirt cheap to buy and saves cleaning it/adding new adhesive.
You can probably buy the back glass with adhesive not much more then the actual adhesive.
Add a comment
Add your answer
Hup will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 426
