Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
Battery will not charge
My Samsung gear 2 want charge..It's not the battery but the part on the watch the 5 little gold dots. One of the is worn. Can that be fixed or replaced..
Score 1
1 Comment:
need to be fixed
by
Add a comment
1 Answer
i had one of mine worn down to not charging. I put a dollop of solder onto the pad, and it started charging.
however, there is a possability that there is a disconnect inside it as well. in which case, a replacement component, or jumper may be needed
Add a comment
Add your answer
mcromartie17 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 326
