I lost proximity sensor when I replaced my cracked screen...help
can i get a replacement proximity sensor because I lost mine when I replaced the screen and now my screen goes black as soon as I make a call which stops access to my screen should i need to pick options on my call
Score 1
Add a comment
1 Answer
all you need is a scalpel or stanley knife, electrical tape, magnifying glass and determination/patience..
so should this happen to anyone else i thought I'd let you all know that it wasn't the actual proximity sensor i had lost but a tiny 'cushion' with two holes the size of pin !$$&*! that went between proximity sensor and the front casing, i decided to try and make one using electrical tape which i cut to size with a scalpel and then very carefully made the holes with a fine needle (and magnifyer) equal spaces apart, all very fiddly and precise but it worked perfectly once my phone was reassembled....it's a lot easier than it sounds....
Add a comment
Add your answer
ju wylds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 257
