12.1 MP camera with 6x optical image stabilized zoom, released in 2007.
8 Questions View all
lens error restart camera
Camera, lens error restart camera
Score 2
2 Comments
I really would love this camera to be fixed...thank you
by
@mia manners what have you checked? Have you looked at the answer and tried it out? What did you find? What is going on with your camera? Give us more details than a one liner :-)
by
Add a comment
1 Answer
Most Helpful Answer
Robert Royer, sounds like a stuck lens. That would give you that error. Check on here for some generic instructions. It is also possible that the DC-DC converter board has failed. There is a fuse on the board that you can check to see if it has continuity.
If you have a multimeter we can also check some of the other components. If you don't than the only fix for that is most likely a replacement of the board and/or a lens replacement depending on your findings.
Score 2
Add a comment
Add your answer
Robert Royer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,214
