Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Screen not staying on
iPad mini a1490, glass and LCD both repaired. When I try to turn the iPad on, the Apple logo comes on, then it goes to a black screen. I let the battery run down and plugged it in. The charging indicator comes on for a second then it goes to a black screen. It's like the screen is shorting out..... Help please
Score 1
1 Comment:
Same issue & model! But my device has never been repaired, it stays powered, I hear the sound when I plug in power, and if it is dark enough I can see that the backlighting is on. On occasion, especially if the device is cool, the screen and touch respond well enough, but as soon as it warms up the screen goes black. I can turn off the device if I'm lucky and swipe in the correct area. What needs to be repaired and is it even worth it?
by
Add a comment
1 Answer
Is the device staying powered on? Do you hear any lock sounds or notice any activity when the screen goes black? Does the device boot loop or just turn black?
If the device is boot looping you may have damaged the gas gauge components that are next to the battery connector when using your tool to disconnect it.
Let me know what you find!
Add a comment
Add your answer
marchinds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 183
