Is there a way to replace a faulty USB port?
My USB port has stopped working.
Tal Ben Ami,
Sorry to say that surface pro 3 is hard to open to do the repairs. Good news is USB port replaceable easily because of surface pro3 comes with full size USB port. if the USB connector internally damaged you can replace it. if you cannot find damages on it check the 5V DC power rails + USB fuse before replacing the USB port. This guid will help you to teardown surface P3, use hot air around 200C air 20 (Hakko) to heat the glued canners and it will help you to open the device without damages.
Cheers!
Where can I buy a replacement USB socket for the Surface Pro3?
Me too! My investigation days it is difficult risky repair.
Hi, i have one surface pro 4, but the usb port 3 dont work any more, its possible replace?
How much does it cost?
If I were to fix it, I'd be interested if you can fix the flicker screen, a line pops up sometimes down, it's not something disturbing, but if I fix it, I'd fix it completely.
Is it still worth fixing?
I thought, maybe usb port 3, changed to micro usb 3.1 type-C, why not?
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 7,612
