Why is my speaker not connecting to my phone?
I turned my Photive Hydra speaker on and made sure that my bluetooth on my phone is on. I can't find the device on my bluetooth list from my phone.
Hi,
Is there a blue light showing on the bottom right hand corner at the front of the speaker when you switch it on?
If not it means that the battery is flat and needs to be charged. Plug in the charging adapter and see if the light comes on.
If it does let it charge for a while then try to connect to your phone.
If it does not there may be a problem with either the charger, the charging circuit in the speaker or the battery in the speaker.
If it does come on when you switch on is it flashing rapidly or slowly?
Rapidly indicates that it is waiting to be paired. Slowly indicates that it is already paired.
Here is the Ifixit guide to troubleshoot your speaker
My speaker is on, (blue light on), my iPhone can’t find the device to connect.
The device name should be listed on your phone as PH-BTW55. If it is not listed, try pushing the pairing button on the top of the speaker in between the volume and select track buttons. This enables the pairing mode and the blue LED light will be flashing quickly. Also, make sure you are within the effective distance of the transmitter being 33 feet or 10 meters. If this still does not fix the issue, there may be a problem internally with the Bluetooth transmitter.
Did you hold down the bluetooth button on top of your Hydra until the blue lights flash rapidly, then search devices with your phone?
I got my speaker 7/6 /18 the blue light be on all the time. When I charge it 20mins later u her a beep to charger. When I turn the music up it not clear sound like how it was a few months ago
My photive sphere bluetooth speaker's blue light is flashing slowly and seems it not connected to any of my devices tried to connect to my devices but couldn't connect and can't even turn off by pressing the power button please suggest how to fix it.
My photive speaker won't make any noise. The blue light only comes on when the power button is pressed. Any ideas what needs fixed? The charger is working, but even on the charger it won't work.
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 76
All Time: 30,846
