A Bluetooth 4.0 portable speaker by Omaker. The speaker has an IP54 waterproof rating designed for outdoor and rugged use. Containing a 12 hour battery life, this speaker is meant to last.
Why will the speaker not charge?
I have been using the charger that came with the device but it is no longer charging the speaker.
Add a comment
1 Answer
Most Helpful Answer
Try changing the charging cable. If this does not work, there could be an internal problem with the power socket.
Score 1
1 Comment:
Thank you. Not sure why the first cable didn't work. It works fine to charge other electronics. But I switched the charging cable and it is charging now. Yay!
by
Add a comment
Add your answer
Carlos Pernia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 672
