I turn the tv on but it turns off
When i turn the tv on it will turn off what can be the cause of that
@sugamama bad power capacitors on the power supply can cause that. However, there are plenty of other things that can do the same. You got to start somewhere, so you might as well remove the back (unplug your TV) and take a look (don't touch) on the power supply.
Check for domed, leaking caps. Post some images with our question so we can see what you see. Use this guide for that.
@tezo same TV same symptoms? What have you checked?
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 806
1 Comment
I turn my TV on and it turns itself off
by Vinson Perkins
