Black & Decker 7.2V Lithium Cordless Drill/Driver. Eleven Speeds with a non-removable battery.
1 Questions View all
Why is my drill not charging?
I just bought my drill a few months ago, I went to use it today after it has set for a while and it wont drive my screw. I keep it plugged in over night before I know I am going to use it. Is it possible that I killed the battery? The drill has worked great up until now. Even with hours of charging the battery dies after three screws if I'm lucky.
Score 7
Add a comment
Chosen Solution
Hey Ray,
It sounds like it is possible that you have overcharged and damaged your battery. This drill's charger is not a trickle charger so leaving it plugged in will damage it. Luckily there is an easy fix. Check out our troubleshooting pagefor replacement guides.
Score 2
1 Comment:
The link wasnt much help. When I put dead battery on to charge. Green light flashes once and red stays on and not charging.. And ideas?
by
Add a comment
I’ve had problems sourcing replacement charger for Black and Decker 12 volt battery. Today I hooked the battery up to a small solar panel 12 volt charger and it has come alive! Put the positive clip onto the large side panel and the other one into the clip on the other side and away it went. John
Add a comment
Add your answer
ray will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 171
All Time: 28,453
