Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
599 Questions View all
Fan is not working
Hi there I have a Mid 2012 macbook Pro 15inch I was cleaning the fans the other day and when to pull the fan connector out and the socket on the logicboard came off the board so I’m waiting to get it soldered back on to the logic board but in the mean time I need to use my mac and I’m scared i might damage it in relation
to temperature the temps its running are:
CPU: 37 -45°C
GPU: 33°C
GPU Diode: 35°C
Memory: 34°C
Battery: 31°C
I just need to know if its ok for me to still use my mac untill I get it fixed any help would be awesome!!!
Score 2
1 Comment
Is there a way I can reconnect the fan by soldering to the motherboard?
by
Add a comment
1 Answer
Chosen Solution
Chad Lawrence no it is not. It is never okay to run it without the fan. There is a reason why it has those fans in the first place. Right now your values look ok but rest assured once you start working on your computer and using it, those temps will go up. So unless you do not like your computer, don't do use it until fixed.
Score 4
Add a comment
Add your answer
Chad Lawrence will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 585
