Why is my battery life draining so fast?
I’m using my Kindle to read for only a few hours a day and the battery life is always low. Why is this happening? Is something wrong with my battery or Kindle?
Get quick access to guides, parts and answers for your devices
That is a common problem that happens. Good question!
You may not be using the optimum settings on your device. It is recommended that you set the Brightness to 10 and turn on Airplane Mode when the Wi-Fi is not being used. While this will extend the battery life, it is also dependent on how long you use the device for each day.
If you are still experiencing battery life problems, you may indeed have a faulty battery. In this case, you may need to replace your battery.
Please tell me where I can get a new battery.
Where can I buy the new battery?
It happened to me also after firmware update in March 2016. It is a bug in the version 5.7.2.1 - something with indexing books. Fixed with manual download a install version 5.7.3.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 74,492
1 Comment
My Kindle is only 7months old but the battery is running low after a single day reading. Really baffled and disappointed. Is this normal ?
by Manonabike101
