perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
Guide
Difficulty:
Moderate
30 minutes
Guide
Difficulty:
Very easy
15 minutes
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
You dont want to walk on any glass floors with those shoes
我不知道!我不知道!我不知道!我不知道!我不知道!我不知道00!
At least you know you dont know
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 59
All Time: 3,974
1 Comment
I sprayed silicone on the boot material
by michelle.jarvid
