Rechargeable indoor/outdoor Bluetooth speaker. Capable of using USB, AUX and SD card for music input. Product released in 2014.
13 Questions View all
Why is my music not playing from the auxiliary port?
I have connected my device with an auxiliary port to my fully charged speaker with the volume all the way up , but the music is not playing. I believe there may be a small crack in the auxiliary port.
Score 1
Add a comment
1 Answer
Chosen Solution
Usually music not playing through the auxiliary port can be fixed by replacing the AUX cord. AUX cords are notorious for breaking and being unreliable, so the first thing you do should be to try using another auxiliary cord you may have around the house to see if that fixes the issue.
You should also verify that you are in the correct mode to play music through an auxiliary input.
Since you mentioned that there is a small crack in the AUX port itself, the port may need to be replaced to properly play music again.
For AUX port replacement and mode verification please see the respective help sections of the Troubleshooting Page.
Score 1
Add a comment
Add your answer
Nina will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 6,696
