Released at 2013, September. Display size - 480 x 800 pixels, 4.3 inches. Internal memory - 4 GB, 1 GB RAM. CPU - Quad-core 1.2 GHz Cortex-A5, GPU - Adreno 203
20 Questions View all
Why power battery is got too hot?
i did factory reset on my phone after that, i can't switch it on full complete and display, but it appears HTC only for long time, help?
sometimes it tells android system errors, how can i fix it?
Add a comment
1 Answer
Chosen Solution
Phone heats up a lot if the system software is stuck in a boot-loop or is stuck at a certain stage of booting where it cannot proceed further due to system software corruption.
Not really sure of a solution to this problem. You can try using another charger, cleaning the charger port socket with a toothpick, use another charging cable. Try another battery.
Score 1
Add a comment
Add your answer
Allen Mdulla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 121
