Why my phone whrite netalpha stopped
why my phone whritting stopped netalpha
Hi,
Taking a gamble that you mean that there is no keyboard showing when you wish to type in a message or similar.
1. Try a soft reset - if that doesn't work.
2. Try a master reset.
Be aware that a master reset will erase all your downloaded apps and user data. It will restore your phone to a factory default condition. It will be like when you first bought it.
Before you perform a master(factory) reset ensure that the battery is charged. Do not leave the charger connected when you perform a master reset. Remove the external SD Card (if any installed).
Here is a link that shows how to do a soft reset and a master reset. Do the soft reset first and see if it solves your problem.
that could not help to remove the netakoha virus, when u reset ur ohone it keeps on coming back.
I've had same problem and it can be fixed but you must root your phone first with Kingroot and then clean it with CM Stubborn Trojan Killer app. Master reset won't help.
thanks for sharing it to us, this help me get rid of that netalpha virus.
unfortunately netalpha has stopped solution
Il cette boite de dialogue qui me rend fou et qui dit netalpha has stopped solution que doije faire pous mendebarrasser svp aidez mois mercie
for me , Disabling or unistanlling was not possible..along with apps created byit(like KMplayer)...i couldn't even delete it in TWRP from system/priv-app and other places...the only things that worked for me(not delete it but somehow disable it) was to :
1-first root phone (iroot/kingoroot/geniusroot & etc....)
2-download 3 apps: " Stubborn Trojan Killer" & es task manager(or sth similar to disable start-up apps) & Avast security mobile which is free.
3-then disable internet activity(no wifi/Data) & install all 3 apps
4- scan with " Stubborn Trojan Killer" (grant/allow root if asked)& try to delete(hopefully delete but it will be created again)
5-in settings of "avast" check scan SDcard too,so when scaning with avastscanning will include internal folders too...it would probably find sth,resolve/fix it
6-use es task manager (grant/allow root)to go to start-up apps and disable all that looks supicious/ have the same time created as netalpha(for me was kmplayer.demo,google services,phone services,and 5-6 other apps)
and for now,your phone is without this virus being operated and disturbing you.unfortunately there is no way to delete the files from system and ..., so for those who doesn't want to format(flash completely) the phone(reset/factory isn't going to help at all for me and many other users), for this is the only way(the only apps that recognize some trojan activity are those 2 for now, which i had sent the files for further investigation by avast team)..hopefully there is a way to cure it otherwise it's just like Stagnet : made to kill you!!!
hello friends ,
i am facing the similar problem. i have a galaxy grand 2 and it is showing the message "unfortunately netalpha has stopped . i am not able to do anything thing as when i respond to the message and press the OK button it again appears on the screen thus, not letting me do anything.
so, then i tried the all data backup reset with my notebook.
it solved my problem and my phone is working in a great condition and it feels like new....
you should also try this technique
Thanks
My phone is doing the exact same thing, do you know how I would do an all data reset from my laptop? I'm very confused!!!
I have a Hp Asiafone AF90 And There it says "unfortunately, Netalpha Has Stopped." How Can Such Troubleshooting
I do all those method for netalpha process and now also show this error
how to get rid of netalpha virus?
first you must root your phone by using kingroot and then scan it by stubboen trojan killers. here are the steps.
1. Install Root check, Root Checker and download and install kingroot in http://forum.xda-developers.com/devdb/pr....
2. open kingroot, click root and when its done, check on rootcheck and root checker basic when ur phone is sucessfully rooted.
3. u can now remove all the unnecessary application.
thats all. hope this could help.
01285023935123456989
01285023935123456789
root it with kingroot, after finished open kingroot in your device. then delete netalpha and other strange app.
restart.
my LG work good now.
hope it helps
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 33,367
5 Comments
could you try asking your question again please
by Jimfixer
https://m.youtube.com/watch?v=haEtNaBUYW...
by gsberhanilhan
thats what you called monkey viruses it is an harmless virus that can fix in pc for programing the phone
by pantefamily2000
my phone lg-p715, keep giving this messege that "netalpha has stoped "and also 'app manager has stoped working ' and not only that but "rain.org.ball. update has stoped", i tried the method of factory reset several times and it is not working at all. whenever i start the internat it keep on irrritating me.please help me solve this problem,
BIRANCHI PUHAN.
by bnpuhan
my htc phone netalpha stopped
by Rakesh Sharma
