A 5", 3 pound personal random orbit sander made by Porter Cable and released in 2010
4 Questions View all
Why is my sander not sanding?
I recently purchased a Porter-Cable 382 at my local home depot. I had been using it for weeks and haven't had any issues sanding down some objects. However I went to use my sander today and it is no longer sanding the surface like it had done so well before. The head is spinning but not sanding, please help.
Score 1
Add a comment
1 Answer
If your sander is not sanding there could be a few different problems. First one being you need a new piece of sandpaper, in which case you should replace the sandpaper. Your sand paper could also be too high of a grit making the abrasive surface not rough enough to do any real damage, try gradually using lower grits until the surface begins sanding. If you go too low and scratch marks appear just work your way up to higher grits. Your device could also not be operating properly in which case I would check this devices troubleshooting page to search for causes for various problems.
Add a comment
Add your answer
jpfoxracing9 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 889
