Budget tablet with 7.00-inch 1280x800 display powered by 1.3GHz processor alongside 1GB RAM and 5-megapixel rear camera.
28 Questions View all
"Data Wipe failed" on Lenovo 3500
Lenovo tablet Stopped working. after trying to rest or factory rest it normally goes to android reboot and factory rest page .
but after selecting "Wipe data/factory rest''" error is:
Data Wipe Failed !
the error repeated in all of the season !
Score 4
4 Comments
it solved - tnx
by
Hi @h1773073 ,
Care to share the answer for anybody else who comes across this problem? ;-)
by
How to solve this problem?
by
How to solve this problem ?
by
Add a comment
Most Helpful Answer
Have you tried doing a factory reset using the Volume Up and Down and Power keys? If it freezes you can use the reset button in the SD card area.
See if this helps: Lenovo A7-40, A7-50 A3500 Factory Reset
Score 2
2 Comments:
This button does not work
by
If the button does not work then you might need a replacement for your device the PCB or new device in general (although I would always choose repair over replace). I would look at the guide I posted and see to replace the board. You can find the part from various third party's, just use the right model of the device or open yours for the part number if you can't find it in the manual.
by
Add a comment
i have the same probleme help us please
Score 1
Add a comment
точно такая же проблема! кто-то смог решить?
Score 1
Add a comment
wipe failed I need solver this problem
Add a comment
Add your answer
1773073 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,140
