The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Questions View all
My psp3000 cannot charge via AC power
Since I tried to user old car charger to charge my psp3000 and it didn't work, I cannot charge psp3000 via AC power anymore.
I've already try to use the adapter with another psp and it's ok.
How do I know that my psp motherboard was short curcuit or just the female plug or damage.
And if the motherboard was short curcuit, can I repair it by myself.
Thanks a lot for your awnsering !!!
1 Comment
Did you repair it ? I have the same problem
by
Add a comment
Chosen Solution
How old is your battery? always look for the easy stuff first :) and than make sure that the battery makes good contact. If I remember right the PSP has fuses on the MB. It has 2 fuses (LD) One marked TB. The other is located beside the power cable disconnect.So by using your car charger you may just have set off one of these. Of course to fix it you will have to open it up and get to them. If you are under warranty with your PSP, don't do it. Go to Sony and replace it. Otherwise, you don't have anything to lose, try to fix it and let us know how it is going. Good luck
http://www.yall.net/Forum/Repair-Center/... and http://www.youtube.com/watch?v=h-TEeWRvl... might help you.
Score 1
1 Comment:
Just realized how old this was :) like I said I am really confused. Hope this is still relevant if not...Oh well :)
by
Add a comment
Hi,
The charging connector is connected to the motherboard by 2x wires cable and small white connector. Near to this connector you can find one fuse (charging fuse). Check it and replace it if necessary. This is most often charging problem.
Regards.
Score 1
Add a comment
I think you might be better than buying new. The price is not expensive. Can not be charted charted with a car. But chart with other charts it 's allright. Your psp would not be damage. A charted in car broke.http://www.excellenttoday.com/
1 Comment:
okay I am now really confused :)
by
Add a comment
Is it mean fuse can find from any place…?? Bro you frist know why psp not tearn on not do any thing damaged your psp…
Add a comment
Add your answer
Thanasarut Sasismit will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 18
All Time: 10,970
