The Philips Portable DVD player, model number PD9000/37, was manufactured in 2011.
6 Questions View all
Volume control not working
Sound is working through the speaker but it's stuck on maximum volume. Turned the volume wheel but volume won't change. Bought used, so I don't have the remote or manual. Is there a way to fix it? Thanks in advance!
Add a comment
1 Answer
Chosen Solution
Hi,
Here is a link to the User Guide for your player.
http://download.p4c.philips.com/files/p/...
If you are trying to use the Volume control on the side of the player (p.13 of the manual) to adjust the sound level and it is not responding, it may be that the control is faulty or perhaps there may be a wiring or component connection problem
Here is a link to the Ifixit guide on how to open the player so as to gain access to the inside of the player and then to the volume control, which should be able to be seen at about Step 3 in the link below, so that you can ascertain what the problem is.
Philips PD9000 37 Buttons Replacement
Hopefully this is of some help.
Score 1
1 Comment:
Thank you so much! I will try the suggestions with success hopefully and follow up :)
-Gina
by
Add a comment
Add your answer
Gina Aguilar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 6,083
