Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
GPS Problems - Not accurate
Hi! I'm new here, so I am not sure how this works. My Galaxy S6 Edge got wet 3 weeks ago. It wasn't anything big and after 1-2 hours in rice it works fine. The only thing (and I am not sure if it got something to do with this) is that the GPS is not working correctly. When I try to use Maps App, it is not accurate. I've done everything I read, even did a factory reset, but the problems continues. I downloaded another navigation app but I received a message that the GPS is not accurate. I wonder if there is any other thing I could do or if this is something that can be fix if I take the phone to a repair store.
Thank you!
Score 1
Add a comment
Most Helpful Answer
Ensure the GPS accuracy is set to high in settings.
Score 1
Add a comment
Use the Power Button to fix the GPS / W-LAN Problem.
Press and hold the Powerbutton more than 10 seconds.
After the reboot works your smartphone without the GPS Problem.
or try it with the Google Play Store App " GPS Status -Test & Fix
You have to delete the A GPS Data first on the left side and then push the right button ( app is in german)
Add a comment
Add your answer
Sandra Velazquez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 962
