The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
51 Questions View all
not picking up paper
it's not picking up the paper to print. Mine is a HP inkjet 6500A. The answers I found in this page was for Canon printer. What should I do? If I can't fix it myself, is there a HP inkjet printer repair location in San Antonio?
Score 5
1 Comment
there is a gear that breaks that drives the paper pickup rollers. the gear actually splits. i have glued it on the shaft and works fine. Its just a really big messy job
by
Add a comment
Most Helpful Answer
Estimado yo tambien tenia el mismo problema, la falla era en uno de los engranajes de el sistema de alimentacion de papel , lo pegue y se soluciono . Te puedo mandar fotos del engranaje
Espero te pueda servir
https://drive.google.com/open?id=0B4Wwlw...
en la imagen puse un espejo desde la bandeja para poder mostrar el engranaje .
Score 2
2 Comments:
Explica mejor como es que lo pegaste y como lograste llegar hasta ese engranaje
by
Here is a translation, thx to Google translate
Dear I also had the same problem, the fault was in one of the gears of the paper feed system, paste it and solve. Can I send you photos of the gear?
I hope I can serve you
by
Add a comment
I glued it and it lasted 3 prints. I believe the heavy photo paper took a toll. I am now looking for a top feeder. Any suggestions?
Add a comment
Add your answer
Genx Ed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,547
