How to fix the E4 error?
When I turn on the rice cooker, the panel flashing E4 and it could not operate.
Score 2
2 Comments:
What type of electronic malfunction? Heater element, thermal sensor or others?
by
For Philips rice cooker model HD4515/60.
by
Add a comment
What model is the rice cooker? Is it a pressure cooker? Did it come with a manual? Usually the error codes are in the back of the manual or you can search them online.
I did find this:
http://www.manualslib.com/manual/265330/...
Doesn't look good.
3 Comments:
by
by
Add a comment
You need to check the cable that connect the sensor inside the head of the lid. Usually it's break, you just need to reconnect and solder the cable and done
Add a comment
Add your answer
Yimiao Cai will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 48
All Time: 19,947
