Cable chewed in half
My sons cat chewed the cable in half. Can it be fixed or is there a replacement part I can purchase ? Thank you
This will fix it: https://www.youtube.com/watch?v=ulN-_FWe...
Knew that was going to be solution when I read the problem
@masonbubba that will depend on where it is split. You can remove the insulation from both sides of the cable end, then solder those ends together and apply insulation after each soldering.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 671
