Color All-in-One Printer/Fax/Scanner/Copier
open back door issue
The back door says it is open even though it is closed. The problem is the contacts on the door won't stay where they make contact. I need a new rubber or cork thing to make it stay where it is suppose to make contact.
Score 2
Add a comment
I had this issue when the printer was relatively new.
The jumper on the rear panel completes a circuit to tell the printer that there is a panel in place, instead of a duplexing unit. If I recall correctly, the jumper on the panel bridges two contacts, whereas a duplexer would make use of four contacts.
The rear panel does not fit securely enough when it clips into place for the two contacts to touch at all times. The design was bad, and I wrote an angry letter to HP about it. They should have used sprung tabs to maintain constant tension against the contacts.
My solution was to apply dielectric grease with a toothpick, being careful only to apply a small amount on each contact, so that the circuit didn’t break with vibration.
Add a comment
I don’t have a duplexer, but I’d like to run the print mechanism and see what is or is not working. I have a jam on the paper feed roller, on the back side of the roller. I can’t determine why it isn’t feeding. and would gladly override, but I don’t know which two of the four contacts need to be bridged
Add a comment
Add your answer
hklehm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 190
