This device is an at-home beverage machine made by SodaStream. The purpose of this device is to make carbonated beverages in the convenience of your own home with the use of syrups and the machine. This particular model was originally manufactured in approximately 2007.
need a new carbonating button
The carbonating button on my Sodastream Jet has broken - cheap piece of plastic. This is the 3rd one it has happened to. Does anyone know where to buy one? The pin slides out just like on a watch band.
Score 5
Add a comment
1 Answer
Most Helpful Answer
There are many used machines on Facebook marketplace or Craigslist that you can find and buy and then use them for repair. I for one found that the button depresses too much and it sounds like that is happening to you, hence the breakage. I took some popsicle sticks, cust them to make an inch length, glued them together, and glued them between the button and the housing. Then I didn't need to press so hard to get the carbonation out of the can and into the bottle. Hope that helps for any future endeavors.
Score 1
Add a comment
Add your answer
virginia ashburn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,625
