Repair guides and support for Panasonic's Viera line of televisions.
422 Questions View all
No power to TV
Panasonic Viera plasma TV Model THP42X50Z:
Went to use remote like normal, wouldn't turn on. Thought flat batteries, went to do it manually...nothing. There is not even the red standby light. Have checked power socket, other items working fro there (stereo, dvd player) Help please!
Score 2
Add a comment
Chosen Solution
@sunsurfer111 this could be as simple as a blown fuse but could also indicate a more serious problem with the power board. You'll have to remove the back of the TV and check the fuse on the board with a multimeter for continuity.
Score 7
6 Comments:
Ok I've done that the fuse is fine.
by
Mavis Senior okay now I am confused? Who are you ;-)? Anyhow. You have the same TV? Describe your error as well as all the things you have tried so we can try to help you as well.
by
Thank you, you helped me eliminate some things, so I could go on with my diagnoses.
by
Thank you so much, My TV is working
by
My tv will not turn on after a power outage. Has happened before and has taken 3 to 5 days to turn on...help!!!???
by
Show 1 more comment
Add a comment
Had a blown fuse. The fuse was replaced and TV is working again.
Add a comment
Add your answer
sunsurfer111 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 8,209
