The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 Questions View all
The light on the drone blinks green then turns red
After I had an accident in which my Parrot Bebop fell about 75 feet, I could not turn the drone on again. When I pressed the rear light to start the drone, first the light blinked green and then turned red.
I at first thought the problem was one motor that had been damaged. I replaced the motor in question, but the light still blinked green and turned red.
Eventually, I took the drone removing the motors, camera, and gps until there was only the motherboard connected to the battery. Now, I still get the same response. When I press the turn on button the light blinks green and then turns red.
Do you have any suggestions for repairing this Parrot Bebop?
Score 2
1 Comment:
Have you found a solution? I have the same problem and am unable to find a cure anywhere.
by
Add a comment
This has to do with either
Disconnected motor
Or disconnected GPS board
Add a comment
i am working on mine right now and it seems that the motor drivers have an open ground or negative, when powering on the motors should activate a few short pulses. my drone does not, but you know guys it would be a !&&* of a lot easier if they would supply a circuit diagram
1 Comment:
Okay, so I took the drone completely apart and searched for any connections that might be questionable. I did not find any obvious issues, just for being able to say that I did something I reflowed the power connections to the mainboard and reassembled the drone. It is working again. Very nice construction of the mainboard. I would say, it's probably 5 layers thick.
by
Add a comment
Add your answer
cmitc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 3,055
