Released in May 2014, the Chromebook 2 features an 11.6" display, Intel Celeron processor, and a 16GB SSD. Identified by model number XE500C12-K01US.
14 Questions View all
Can the charging circuit on the Chromebook xe500c12 be replaced?
The charger died, and in the process of trying to retrofit a charger I seem to have damaged the device. Now that i have a new replacement charger, there is no light when the charger is plugged in, and the device does not charge.
Can the device be fixed? Could it be the charging circuit? Can anything be replaced?
Add a comment
1 Answer
It depends. Perhaps check all the capacitors and other parts for shorts, then it looks like you might have to track down a replacement PMIC of some sort and solder it in. Do you have a picture of the board?
Add a comment
Add your answer
Noel Arnold will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 190
