The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
39 Questions View all
Can I use a different model to replace the LCD?
Okay, I have the Verizon version of S4 SCH-I545. The LCD needs to be replaced. I also have available a working LCD from the ATT I337 S4 which includes the frame. I read that they have different frames and home flex so you can't just use any version to replace LCD.Can I just switch the LCD to the Verizon model motherboard?.Do all the motherboards match up? Can I just transfer all the parts to the I337 LCD frame? Or is the home flex connection different on the verizon motherboard?
Score 1
1 Comment
It says that the S4 active is AT&T only... Is it unlocked?
by
Add a comment
Chosen Solution
No. The Samsung Galaxy S4 screen is completely different from the Samsung Galaxy S4 active screen. Neither will work on the other.
Score 2
1 Comment:
Are all the ATT S4's using an active screen? I don't know if mine is active.Anyway to check?
by
Add a comment
yeah i have a galaxy a50 and the model is a505U and i used a a505f, it was working fine at first then vertical lines started appearing. it’s most likely because the different models.
Score 1
Add a comment
Add your answer
xsilicon9 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,511
