The fourth-generation Surface Pro tablet, released October 26th, 2015.
210 Questions View all
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
Score 8
1 Comment
answer is not even about the hinge, only addresses the easy answer
by
Add a comment
Most Helpful Answer
Microsoft Surface RT Kick-stand Replacement
Score 2
4 Comments:
answer does not address the broken hinge!
by
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
by
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
by
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
by
Add a comment
not helpful--hinge broken & not the stand
Score 2
Add a comment
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
Add a comment
Hi Grant,
To replace the right hinge, you'll have to open up the tablet. You can do this by following this very helpful repair guide!
Microsoft Surface Pro 4 Kickstand Hinge Replacement
Add a comment
Add your answer
Grant Smith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 15,605
