A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
How to test power supply
Hi my ps4 turns on then instantly off. I'm 99% sure it's a power supply fault from videos I have seen on youtube. However I would just like to check my power supply with a voltmeter before buying a new one. My power supply model is ADP-240AR.
Score 8
1 Comment
Are you familiar with the washer fix? Have you attempted it? What makes you think it's the psu?
by
Add a comment
Most Helpful Answer
The PSU provides a permanent +5 VDC on the side connector. This same connector has an input, used to tell the PSU to provide +12 VDC on the 2 big metallic legs soldered on the motherboard.
To make basic tests on the PSU you can:
- remove it from the console
- plug it in the AC with the power cord (from this point, manipulate the PSU only by touching plastic parts!)
- connect a multimeter on the side connector and check that you get +5VDC on some pins (can't remember which ones, just test)
- verify that you have 0 Volt on the 2 holes where the big metallic legs are supposed to be plugged in
- use a wire to shortcut the first and the last pins of the PSU side connector, this should tell the PSU to provide +12VDC
- check with the multimeter that you get those +12VDC on the 2 holes
If yes, your PSU seems to be working.
If +5VDC and/or +12VDC is missing, the PSU is the culprit.
You can find tutorials on the net, just search "PS4 ADP-240 PSU Test" for instance.
Score 7
4 Comments:
Does it work if you just shortcut the side connector of the power supply so it will always give the +12VDC?
by
I'm looking to do this on a different model. ADP-300CR. Just to clarify, I'm wanting to test for 12 volts on the area where the motherboard prongs insert into the PSU?
by
I am getting 5 v output , but not 12 v when shorting the PSU side connector. Can we identify the faulty component and replace it
by
Wrong information!!!
Need to short first and second hole on the left side and not the first and last.
I tried first and last. It doesn't work.
I followed instructions of this post and thought my PSU was bad. I received new one, it didn't power my PS4. After googling, I found that you need to short the first and second pins. I tested my old PSU, it was giving 12 volts. Wasted money on a new PSU.
Please update this post. And readers please take note.
by
Add a comment
1.Plug in two prong power cord into PSU
2. Flip over power supply
3. Insert positive and negative prongs from multimeter into two holes
on the bottom. Be sure they are fully inserted and not touching any
metal or each other.
4. Set multimeter for DC voltage at ~20v.
7. Use a small piece of metal and make contact with the
first (5VSB) and 3rd(ACDC_STBY) pin
of the connection on the side.
Make sure whatever you are using to jumper the pins makes
contact with the metal connectors in the connector.
This turns on the power supply.
8. If you have done it correctly and the power supply is good,
you should get a reading of around 12 volts as shown.
Score 5
Add a comment
Short first and last pin to test the 12 volts output.
Score 1
Add a comment
Hi, i need your help regarding my adp-200er from 12xx serie. i'm trying to check if the psu is my problem on my "no power" ps4
so here is my situation. i put black and red sticks inside the PSU, then i try to jump the 4 pins to watch my readings
when i jump the first and second pins i have no readings
when i jump the first and third pins i have the 12vdc reading
when i jump the first and fourth pins i have no readings
when i jump the second and third pins i have no readings
when i jump the second and fourth i have no readings
when i jump the third and fourth i have the 12vdc reading
do you think the PSU is half working? do i have to replace it?
thanks anyway for any advice
1 Comment:
If your getting the 12v I would have to say Power Supply is GOOD.
by
Add a comment
you might check your APU chip, if that comes off, or if any of the suturing points come unsutured, then you need to get a new ps4
Add a comment
Add your answer
Louis Greenleaf will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 54
Past 30 Days: 240
All Time: 57,207
