Ear pad leather slowly coming off
Hi
The leather on the ear pads will soon fall off. Half off it is already loose.
The leather is not damaged or anything. It is just getting loose on the sides.
How can I fix it? Thanks
Hi
@dinbab you need to replace the ear pads. The leather is tearing of the plastic part that connects to the headphone. When you remove the pads you will notice that the leather is bend over and attache to the back of the plastic. This video shows how to replace the pads.
It's actually simpler than that, you can use a credit card to 'tuck' the leather back into the groove. It works really well, and I'd recommend trying it before going through removing the entire pad.
That video are for the first edition solos. here is the video for the beats solo 2'.
After removing the ear pads follow these steps and you will have a permanent fix!
yeah but only the leather is getting loose on a little spot so I dont want to take apart my headphones
I actually was able to tuck the “leather” back in the grooves with the a thin pruning knife. Worked great.
Did the tuck move (actually used the little liquid metal prong thing that comes with an iPhone because it was really skinny and I used the round edge to push the leather in). It worked great!
To fix it you have to buy a new pair of beats ear pads, is batter choose to buy a replacement pair of ear pads because will cost between $20 - $30 dollars depending on the model and color, we sell worldwide replacement parts and a lot of consumer give us 5 starts for our services and our unique ear pads models, just check out here all ear pads, we will give you a tutorial on how to replace it and a repair kit if you want https://beatskinstore.com/product-catego...
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 78,677
2 Comments
It's actually pretty simple, you can use a credit card to 'tuck' the leather back into the groove. It works really well, and I'd recommend trying it before going through removing the entire pad.
Source: How to put black leather around beats headphones
by staelthyninja11
I made a video on how I fixed my husband handset
https://youtu.be/mVTXCghufV4
by leidy Riehle
