Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
204 Questions View all
Replaced digitizer not recognizing touch
I recently replaced the digitizer on my Apple Watch but I did not replace the LCD. I followed multiple guides to make sure every thing was going correctly. I ordered one digitizer/glass unit from Amazon and it did not work. I figured it was defective so I ordered one from iFixit, who I trusted more. It did not recognize my touch either. The only thing I didn't do was apply LOCA glue because it wasn't needed as far as I was concerned. Any help with this issue?
Score 2
Add a comment
Most Helpful Answer
I repaired an apple watch myself, but I used a full digitizer/LCD unit.
Although you probably tried this already, when I firstly reassembled my apple watch, touch wasn't working either, but only because the connector wasn't connected properly, although I was convinced I had it connected correctly. Maybe checking this could help you out.
Score 1
1 Comment:
@klausibert which was the connector which was not connected properly? The one linking on the top left of the watch from which the display ribbon cables start?
by
Add a comment
I have the same issue and ordered a new digitizer to replace it, Did you ever find a fix? Apple wants to charge $200
Add a comment
Add your answer
Ethan Turner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 182
