The Philips Norelco Shaver 3100 is an all-in-one styling trimmer. It has multiple attachments for all your grooming needs. It is identified by model number QG3330/60.
7 Questions View all
Where can ii get a replacement battery
Battery is dying - where can i get a replacement
15v 5.4w 1310/A
Add a comment
Try batterupgrade.com, send them an email.
Good luck!
Add a comment
You can go to a battery shop such as Batteries Plus. They can change the battery for you or you can do it yourself. It requires care in disassembly and reassembly but when shavers cost $100.+ dollars, it's worth it.
Add a comment
I had this same issue with mine (Phillips Norelco Multigroom, not a 3100 model but one with a turbo button on it) and when I took it apart (great tutorial on Ifixit.com) I discovered that it is just 2 AAA batteries soldered in. I just purchased a set of them at my local store and soldered them in. Works great again.
Add a comment
Add your answer
Lenny Romeo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,501
