The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
How to replace trigger spring?
Hi, I've got a controller that was dropped and the trigger is now loose. When I opened it up I see that the small spring that pushes the trigger back up is broken. I have a replacement spring and bar, however I can't seem to remove the old one. Anyone smarter than me out there got any tips?
Thanks.
Score 2
1 Comment
doubtful there is anyone here smarter than you, google is your friend.
by
Add a comment
Most Helpful Answer
There should be a bolt through the middle, holding it in place. You can stick a needle or something small and thin in the end of it and it will come out.
Score 2
Add a comment
bend a paperclip to push it through
Add a comment
Add your answer
barrypearson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 7,853
