The Samsung Epic 4G is the first US released version of Samsung's Galaxy S II. Also known as the Samsung Galaxy S II Epic 4G Touch.
16 Questions View all
Galaxy S2 turns on for a few seconds then turns off.
I have a Samsung Galaxy S2 Epic 4G, and the problem is that when I try to boot it on battery, it turns on for a few seconds, and then turns off. But it works fine when on charge. Do I need to get a new battery? Or is there something else wrong that I need to replace?
Score 1
Add a comment
Chosen Solution
Daemeon,
Check the battery's physical appearance whether it swollen or not. if it is swollen just disposed the battery proper way & buy a new battery otherwise clean the battery terminals and charge the battery at least 15mins. hope you have good result :-)
Score 2
Add a comment
Most Helpful Answer
I would definitely start off by getting a replacement battery. The symptoms you are describing point to most likely a faulty battery.
Score 3
Add a comment
Add your answer
Daemeon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 435
