Repair and support for the third generation of the Flip portable speaker by JBL.
63 Questions View all
Why does my JBL Flip 3 not produce sound?
I just bought a JBL Flip 3 2 days ago, i didn't get warranty because i couldn't afford it. i have charged it twice and haven't gotten it wet, or handled it improperly. i woke up this morning and went to play some music through it and there was a rattling sound whenever i played anything from it. so i turned it off and then back on, and not it doesnt produce any sound whatsoever.
Score 1
Add a comment
I have this problem too, I think the problem was the cable I used to charge, I used a cable that was not original, try to unload completely, leave the battery to zero, then charge again, remember to use the original cable . If it works, leave your comment here, thanks.
3 Comments:
i will try this did it work for you?
by
Bagaimana hasilnya?
by
Les cuento mi experiencia, el mio funcionaba perfectamente, hasta que la bateria dejo de cargar y solo funcionaba enchufado, lo abri, le quite la bateria que estaba inflada y habia roto la carcaza de tanta presion, eso ayudo a desarmarlo ya que tiene un flex que da toda la vuelta y es imposible sacar. Cuestion que cuando lo enchufaba sin bateria no tenia sonido, la conexion de la bateria es necesaria para que funcione. Volvi a conectar la bateria vieja y sonaba asi que solo queda comprar el epuesto. Espero les sirva
by
Add a comment
there is a bottom on the inside on the motherboard labeled ir5 and when loose doesn’t play music you have a figure out a way to tighten it back on
Add a comment
Add your answer
Cocoa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,330
