This device is an at-home beverage machine made by SodaStream. The purpose of this device is to make carbonated beverages in the convenience of your own home with the use of syrups and the machine. This particular model was originally manufactured in approximately 2007.
Leaks when making soda
when making soda, the gasket located where the bottle screws in is old and hard.
the soda leaks down the bottle and onto the counter.
i cannot find a replacement gasket on line??
cujim
Add a comment
Most Helpful Answer
I used Sugru, which you can buy on Amazon or Target and made my own gasket. The object is to not make it so thick just about a string of 1/4 inch Surgru around the inside, screw the bottle in just enough to make a slight screw impression and then take the bottle out and let it dry for 8-10 hours.
You've now made your own gasket with a rubber material that will last a couple of years.
Score 1
2 Comments:
Thank You! I will try it
by
FYI - I found so many soda streams in garage sails and/or on the stoop in the street of Brooklyn ..
by
Add a comment
iFixit doesn't carry them; I'd check with Sodastream to see if they sell a replacement. You might have some luck in taking the gasket to a hardware store and see if they have a similar gasket.
Add a comment
Add your answer
JIM Nichols will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 1,662
