mobile data not working
Mobile data not working
I assume you have probably fixed this by now, But I was having the same problem.
What solved mine easily was Apps > tap Settings > Mobile Networks. It was set on 4G/3G/2G (autoconnect) as default, I switched it to just 3G/2G (autoconnect) and it instantly connected to mobile data. Then I switched it back to 4G and It was now working with a 4G connection.
Hope this helps anyone else searching for and answer when having problems connecting to mobile data.
My Phone - Samsung A5
Super helpful..thank you..worked like a charm....
I on my mobile data but not working in my mobile when I check in other it is working mobile data on is not seen
Nice , worked very perfectly
WTH i searched for hours how to fix it and it was this easy :) weird glitch to happen though. Thanks so much!
Computer, turn on mobile phone
Hi,
Check that the following setting has been enabled:
Go to Home Screen, tap Apps > tap Settings scroll to and tap More networks > tap Mobile networks> tap Mobile data tap OK if prompted.
I'm a UK TalkTalk user and could not get data working on my 2017 version of the Samsung Galaxy A5.
The fix for me was to enter the correct settings for the service providers APN.
SETTINGS-CONNECTIONS-MOBILE NETWORKS-ACCESS POINT NAMES
Talk Talk have a help page for this (and other models) see below which i followed and fixed my problem.
http://help2.talktalk.co.uk/android-phon...
The answer for others experiencing the no mobile data problem would be to check out the APN settings for their mobile and OS version from their mobile service provider.
What network are you on?
Mine wasn't working but after I contacted Sky they emailed me the correct settings , which I input into my device, and now everything is working fine.
Talk to your service provider.
I simply removed the sim card, wiped it clean and replaced it. VOILA! Normal service resumed.
This is a very common issue many peoples face it. You need to do setting in Sim cards check from which one Sim card you want to use data. Click sim card and slect data on. Remember if you in roaming then don't forget to on roaming data.
Select also 3g,4g network that you are using. Restart your device and check again... you will enjoy the mobile data surely.
My phone is a Samsung galaxy A5 SM-A520F, I believe it can only have 1 sim card at a time?
OK. So you got the solution for your problem or not?
have you changed the APN settings on the device.
Settings>>>More Networs>>>VPN settings>>>Access Point Names.
make a new APN with the settings you get from your carrier
I have already written them a letter but they take 5 days to respond... thx though :)
Set up your APN ..fixed my issue of data not working just search your APN settings for your provider..it should give u step by step..I'm with Lucky Mobile and it took 2 min to
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 86
All Time: 116,852
10 Comments
My galaxy a5 wont work on 3g or 4g only in 2g/edge if i try to switch on 3g only not registering in network pls help
by Andrei Cirstea
by lekan oladejo
I have LG G3 mobile had Samsung--now how do I make sure networks have correct passwords to not be offline?
by Terri Ann Winiarz
It says LG phone and networks offline-but WIFI is all good? At same time-my Mobile Data is off now-and I try to verify my passwords with YAHOO, GOOGLE AND FACEBOOK-i HAVE CORRECT SHAW WIFI PASSWORD; HOW TO SYNCRONIZE -i BELIEVE THIS WILL SOLVE OFFLINE ISSUE? tHANKS
Hello, I have a problem with my Samsung j5 2016, my mobile data won't work after custom rom updated to 7.1 please help or you can email me directly jezzcabahug@rocketmail.com.
Thank you!
by jezzcabahug
Show 5 more comments
