Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
MacBook air hinge question?
i bought a macbook air on ebay that i am repairing and it does not have the little plastic or rubber(not sure which they are)pieces in the hinges that holds the wire in. i was wondering if someone could tell me what they are called and point me in the right direction to buy them.
the model number on the air is a1237
Thanks in advance,
Cody
Score -1
Add a comment
Most Helpful Answer
Take a look at this repair video to see if you can identify the parts you need: http://www.wonderhowto.com/how-to-repair...
Score 1
2 Comments:
good start +
by
right around 7:18 what he refers to as the plastic grey insert. the insert is what i need. Thanks you for your help.
by
Add a comment
APPLE WILL COVER EVERYTHING that is broken even if it's out of warranty!!! I bought my macbook air new in March 2008 and in 2010 my speakers busted and both hinges completely broke. When I mean "broke" the right one was complete detached from the base and the left one finally got detached last week (January 2011). The screen went blank and instead of a laptop I had two hunks of junk - a broken screen and keyboard base.
The apple website is no help and don't call customer service because if you don't have an extended service plan they will not help you. Though the website clearly states that the breaking hinges are a FACTORY DEFECT you can't speak to someone unless you have a warranty.
I made an appointment with my local apple store with their Genius Bar service. I explained what happened. They took it and replaced everything at no cost - The clam shell, the sound board, the hinges, and even a new 1.6 GH process/Logic board. I'll be honest I was almost crying when I saw what they did. Heck, they even cleaned it inside and out so it looks brand new. Apple went above and beyond what was broken. For this I am grateful.
I hope this helps. Go to a major market Apple Store like mine in Los Angeles(not a ma and pa or department store) because they'll give you the best (and free) service.
Good luck
Add a comment
Add your answer
Cody will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 3,225
