Repair guides and support for LED, LCD, HD and other Vizio TVs.
Issues with Vizio Remote
I bought my 3D Vizio in 2012. I dropped the remote last month and it stopped working. I have since purchased two remotes - the same one that was damaged - and neither of them will work. Fresh batteries, but neither will operate the TV. Am I doing something wrong? Does it need to be coded in? I've also tried two different universal remotes, and had no luck with them either!
Score 3
Add a comment
Chosen Solution
Dustin, your remotes do have to be programmed to sinc. with TV. The manual that came with remotes should have explained this/procedure. In case you have no manual, I will post links to instructions on how to program remotes. Dustin you can also do a google search your remotes make and model# manual.
VIZIO programming codes, 1169 1168 0081 0112 0143 1011
0050 1000 1222 1322 1189 0218
0219 0220 0221 0222
Check the attached links,instruction and guides, Good luck
I hope this helped you out, if so let me know by pressing the helpful button
http://cdn.vizio.com/documents/downloads...
http://vizhdtv.com/vizio-tv-remote-codes...
http://www.brighthub.com/electronics/hom...
Score 1
Add a comment
The remote I have now, and the remote that came with the TV are the same type... they don't have a "TV" button or a "Set" button, so I have no idea how to use those instructions. Here is the remote I have - http://oi65.tinypic.com/33bo0n4.jpg
Add a comment
Add your answer
Dustin Grubbs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 3,839
