The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40 Questions View all
unable to turn it on
i have a problem with my laptop "dell inspiron 3521" when i press on power button nothing is happening there is no response , and when i connect the adapter , the led of the adapter starts to blink and stops when i disconnect the adapter from the laptop
3 Comments
Waleed Hamdy have you checked teh output of your AC adapter? Is it the right voltage for your Dell? what else have you tried? How long has this been going on?
by
since yesterday my laptop is not working it happened suddenly , i think the adapter is working well as i have tried another adapter and it had made the same blinking on connecting it to the laptop
by
Try to remove the battery, the AC adapter and tyour RAM memory. Then push and hold down the power button. Do so for a few minutes. Then replace the battery and one memory module as well as the AC adpater and see if it shows anything.
by
Add a comment
1 Answer
Chosen Solution
Waleed, As oldturkey suggest try a reset. From post in another forum I read, possible it could be a faulty/worn out battery. Check link below. Hope it helps, Good luck.
http://www.geekstogo.com/forum/topic/340...
Score 1
Add a comment
Add your answer
Waleed Hamdy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 151
