SMC problem in A1342
Hi everyone! Sorry for my english. Hope you understand.
I have an A1342 Macbook White. It was working fine, but I decided to install an SSD drive. After that, I'm having an strange SMC problem.
OS X (El Capitan) install was succesful, but Macbook's only way to boot up is holding the power button for almost 15 seconds. Magsafe led's green. Led light indicator goes crazy : blinking, smoothing, etc.
When it finally power up, fan speed is really high, battery is not detected, and system runs very slow.
I've tried installing again the original HDD, but nothing happened.
I already had this problem whit another A1342, and resetting the SMC solved it. But... When I try to reset the SMC in this Macbook, it just doesn't do anything! Doesn't even try to boot whit the reset SMC's keyboard combination pressed.
If I keep pressed the power button, it "starts" to boot, but, if I press the combination, it inmediatly power off.
Any answer will be useful! Thanks, and sorry again for my english.
4 Comments
Can you give us the make & model info on the SSD you put in.
by DanJ
What happens when you put the original HD back in does the system work then?
by DanJ
Thanks for the answers! SSD is a Kingston UV400, 120GB, SATA3. I've installed it in many macbooks like this one and never had a problem before. If I put the original HD back, it stills having all the issues Ì comented.
by Nico Corradini
Your systems specs: MacBook 13" 2.4 GHz Core 2 Duo (Mid-2010)
Your SSD's specs: Kingston UV400
by DanJ
