replace Deterriated charge contacts
How to replace charge connector
Enjoy, In some of the forums people have had success using a conductive circuit writer pen to build charge terminals back up to work good again.
Samsung Gear S replace charge connector, link below shows tear down of watch at which point you will be able to access charge terminals and possibly replace, may have to desolder and solder new.
Check the attached links,instruction and guides, Good luck
Thanks for your help. I ordered the 841-P nickel conductive pen resistivity 1 Ohm by MG Chemicals from Amazon under $15!! Worked great. It set up in about 20 minutes. How ever I let it stand overnight to be sure it was completely dry. This is day one so will be keeping track as to how long this last before I have to re apply. I will use this pen until it is completely gone if need be. Maybe by then I will have gotten my moneys worth out of the watch and can upgrade to something better. Thanks again for your help
Love this watch. Ordered the part off ebay going to try and repair.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 905
