How do I clean my fan properly?
I think my fan has dust in it; how do I get the dust out?
Julia, While computer apart do not just clean the fan, clean every thing you can using a can of compressed air, this will ensure proper cleaning and reduce damaging heat build up on internal components. I will post links that will help you see how to disassemble laptop and instructions on cleaning. Check the attached links,instruction and guides, Good luck.
http://www.howtogeek.com/194479/how-to-c...
You must first remove the fan cover. After that, use a can of compressed air and blow directly into the fan. Blowing into the fan via mouth will not remove the dust.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,906
