5W Mighty Dwarf Omnidirectional resonance speaker.
7 Questions View all
The red and black wire came out
Hello my name is nokia Thompson, I acidentally knock it over when I was putting something up and it didn't shatter but the bottom peice shows the blue battery pack I think? It has a red and a black wire but on the inside bottom of the speaker it's wires are still connected. Is there a way to connect the other red and black wires?
Add a comment
Chosen Solution
nokia, both wires will have to be rejoined to corresponding wire, normally wires would be stripped of a little insulation, shrink tubing put on/slid over wire out of way, stripped copper wire meshed or twisted together and soldered to secure connection. After solder cools feed the shrink tubing over the soldered joint and heat it with heat gun or carefully with small flame till it shrinks, rapping tightly around the joint. Electrical tape can be used in place of shrink wrap (just not as reliable I feel).
Check the attached Video link, instruction and guide on how to solder wires, Good luck
I hope this helped you out, if so let me know by pressing the helpful button
https://www.youtube.com/watch?v=Q9G9gaok...
Score 2
Add a comment
You'll be looking for a local electrocution or wiring company for this if you don't feel like going out a buying speaker cable and a soldering iron. Wouldn't cost you much either way.
Add a comment
Add your answer
Nokia Thompson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 567
