Portable Bluetooth speaker released in June 2015. The speaker features ClearAudio+ Technology and LDAC Technology. Model Number: SRS-X55.
11 Questions View all
Why is the sound skipping on my speakers?
Hi!
I've had my SRS-X55 for about four months now and it's been working like a dream. But in the last few weeks, when it's connected to my Macbook via Bluetooth, I've been having a problem where the sound skips/cuts out for a second about once every four to five seconds.
The sound is fine when I connect the speakers to my phone and the problem doesn't seem to be associated with just one program either.
I've tried unpairing and reconnecting, as well as a soft reset of my speaker. Is there anything else I can do?
Thanks!
Score 1
1 Comment:
Hi, Just wondering if you could try connecting your Macbook to another BT speaker and see if it happens as well, to prove if the problem is with the computer or not as you say that it is alright when you pair the speaker with a phone.
Is there any difference regarding location or distance etc of speaker/Macbook than from before when it worked OK? Just wondering whether the Macbook or its' power adapter etc is causing interference to the BT signal. When you try the speaker/phone setup is it in the same location as the Macbook /speaker setup?
by
Add a comment
1 Answer
I have the same issue from my mac with the SRS-XB30.. Was there ever a resolution for this?
1 Comment:
I also have a SRS-XB30 that has suddenly started skipping. I've tried through multiple devices and it seems to be the speaker that is malfunctioning. It seems to work better when the speaker is pointing up which makes me think something on the inside may be loose. Any thoughts?
by
Add a comment
Add your answer
fra09sam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 1,929
