Repair guides and support for electric and stove-top kettles.
54 Questions View all
Whats the technical name for the silicon gasket inside the kettle?
There is a circle rubber strip that goes around the stainless steel plate which heats up. I knows its used to make it a water proof seal and support the plate but what is the actual technical name for it. I tried searching everywhere.
Score 1
Add a comment
1 Answer
Chosen Solution
nabeel, I believe it may be the kettles base to element insulator or base sealing ring in question. You may have to call the manufacturer for this info. directly, as different manufacturers use different names for parts.
Check the attached link for more info., Good luck.
https://www.google.com/patents/CN2033747...
http://www.explainthatstuff.com/how-elec...
Score 2
4 Comments:
thanks for answering but i still need to know the actual technical name for it, there is defiantly another name used for the actual process or the part itself which i cant find. The pages above i have come across when searching.
by
nabeeljan, you may have to call the manufacturer for this info. directly, as different manufacturers use different names for parts.
by
will do thanks.
by
Hey @nabeeljan, did you ever manage to find a name for it? I have similar thing gone missing, and as a result the kettle is not able to stand on its base and wobbles, but I am not sure where to look.
by
Add a comment
Add your answer
nabeeljan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 27
All Time: 914
